sweerik
May 25, 2024Aspirant
Outdoor RBS50Y settings
Hi outdoor RBS50Y there are two settings that I cannot figure out. 1. INDOOR - OUTDOOR setting. What is the difference? 2. SYNCHRONIZE - activated/deactivated. (NOT related to add to add sat...
CrimpOn
May 25, 2024Guru - Experienced User
This sounds fascinating. Would love to help but do not have an RBS50Y. Could you please attach screen shots showing these options? (They do not appear in the RBS50Y User Guide, so it a bit of a mystery.)
Thanks
- sweerikMay 26, 2024Aspirant
Hi.
Interesting.
Indoor / outdoor appears in app as well as web portal. App image included.
Synchronize appears in web portal. In Swedish 🙂 (av=off, avaktiverad=deactivated). Web portal image included.
RBS50Y is utomhus=outdoor and satellite #1 in table.
Thx
Erik
- CrimpOnMay 26, 2024Guru - Experienced User
Thank you for providing the screen captures. This is a description, not a setting. It can be changed to any combination of letters and numbers. In the web version, clicking in that panel brings up a box where the user can change the information.
For example, clicking in this area:
Brings up this input box:
Device Model and Device Name can be changed to anything you like. There is similar feature in the Orbi 'app'
