sweerik
May 25, 2024Aspirant
Outdoor RBS50Y settings
Hi outdoor RBS50Y there are two settings that I cannot figure out. 1. INDOOR - OUTDOOR setting. What is the difference? 2. SYNCHRONIZE - activated/deactivated. (NOT related to add to add sat...
sweerik
May 26, 2024Aspirant
Hi.
Interesting.
Indoor / outdoor appears in app as well as web portal. App image included.
Synchronize appears in web portal. In Swedish 🙂 (av=off, avaktiverad=deactivated). Web portal image included.
RBS50Y is utomhus=outdoor and satellite #1 in table.
Thx
Erik
CrimpOn
May 26, 2024Guru - Experienced User
Thank you for providing the screen captures. This is a description, not a setting. It can be changed to any combination of letters and numbers. In the web version, clicking in that panel brings up a box where the user can change the information.
For example, clicking in this area:
Brings up this input box:
Device Model and Device Name can be changed to anything you like. There is similar feature in the Orbi 'app'
