Hotkey
Mar 27, 2023Aspirant
Outdoor RBS50Yv2 won’t sync to AC3000 router anymore
Outdoor unit has been working must if the time for years. Recently it disconnected and rebooting wouldn’t fix it. I brought it inside and tried the sync process a few feet from router but it resolves ...
Hotkey
I’ll do that. Also that link just opens to my post when I click it. ??
CrimpOn
Mar 27, 2023Guru - Experienced User
Totally "My Bad". Had too many windows open at once. There are many posts on the forum, such as:
- HotkeyMar 27, 2023Aspirant
Ha - sounds like my browser as well! I'd sure say lots of others same issue and indicates poor design and false advertising I'd say. It was "partially" protected for the past 3 years but if I can get it up and running again, I'll mount it up under an eave or porch roof.
If I can't, does Orbi have a newer/better outdoor solution that would work with my router that you know of?
Thanks for the fast accurate help too!
- CrimpOnMar 27, 2023Guru - Experienced User
Weather rated products is not one of Netgear's strengths. The only "outdoor" Orbi satellite is the RBS50Y. Nothing at all for the AX product line or the WiFi6E product.
As one of those posts indicated, at least one commercial installer put regular Orbi satellites inside plastic weatherproof utility boxes.
The significant difference between a "WiFi Extender" and a "satellite" is seamless roaming. There are a number of weatherproof WiFi Extenders that will work with any WiFi system (from any manufacturer). They work great to extend WiFi coverage for non-mobile devices (pool controllers, solar systems, cameras, etc. Mobile devices are where roaming is an issue.
"Honey. Why is Netflix not streaming right on my tablet?". "You came outside (again). Go into network settings and choose the WiFi again. Remember when you go back inside to reconnect."
So if I understand your comments, if I mainly want the extension for security cams, garage opener security and stationary media devices I could get any brand OUTDOOR unit and be good to go? (Understanding that using the occasional iphone or wifi only ipad maybe be hit/miss? At the rick of wearing out my welcome with your help, might you suggest an outdoor unit or 2 that I might consider? (I'll google for the same to see if I end up at the same place!)
Thanks again!
