pryner
Jan 05, 2020Aspirant
outdoor receiver antenna for orbi
I have a rbr50 ac3000 with one inside satellite and one rbs50y outdoor satellite. The system works well and I can get high speed internet from anywhere in my one acre lot. I have a second block bui...
CrimpOn
Jan 05, 2020Guru - Experienced User
From what I can see, Netgear does not sell an outdoor rated WiFi access point besides the RBS50Y, which as you have noted is expensive.
There are solutions which will provide coverage to the block building, but there are no solutions that will integrate with the Orbi.
Would there happen to be a window in the block building that faces the outdoor Orbi?
If so, you might consider placing a WiFi extender (any brand) in the window where its antennas are visible to the Orbi and also visible to devices within the building.
