pryner
Jan 05, 2020Aspirant
outdoor receiver antenna for orbi
I have a rbr50 ac3000 with one inside satellite and one rbs50y outdoor satellite. The system works well and I can get high speed internet from anywhere in my one acre lot. I have a second block bui...
michaelkenward
Jan 08, 2020Guru - Experienced User
pryner wrote:
I have a second block building about 75' from the outdoor satellite and cannot get a decent signal from the outdoor satellite. .
That's a strech for consumer grade wifi.
Are the buildings on the same power circuit?
pryner
Jan 09, 2020Aspirant
Actually they are on separate electrical systems. Each has its own meter and main box
- michaelkenwardJan 09, 2020Guru - Experienced UserThat rules out Powerline.
- CrimpOnJan 09, 2020Guru - Experienced User
I was entirely serious about "is there a window in the building that faces the RBS50Y."
This is one situation that I think calls for a "Range Extender". They are widely available and dirt cheap.
Netgear's EX3700 is $30: Amazon Link
TP-Link's RE220 is $23: Amazon Link
TP-Link's RE450 is $59: Amazon Link
The more they cost, the higher the throughput.
They can all be programmed to have the same WiFi name/password as the Orbi. All are designed to be connected to a standard electrical wall outlet. I would use an extension cord and stand it in the window facing the RBS50Y. Window glass typically does not impede WiFi signals as much as concrete block. Every device inside the block building should "see" the antennas, as should the RBS50Y.
I'd spend $30 to try this if the alternative is 10 times as much.
Of course, no window = "sorry. My Bad."
- prynerJan 09, 2020Aspirant
no direct facing window. One faces south almost purpendicular to the satellite which is to the west. There is one west facing window but it is 20' to the north of the satellite and more than 30' away from the satellite. I like the idea though and the cost is low enough to give it a try.
Thanks
