Pskap's avatar
Pskap
Outdoor satellite use?
Does NETGEAR sell an outdoor compatible satellite unit? I need to find a way to get a stronger signal to a corner of our backyard. However, it is in harsh conditions (oceanfront). Suggestions welcome.
  • CrimpOn's avatar
    CrimpOn
    Feb 26, 2021
    Pskap wrote:
    Does the RBS50Y outdoor Satelite work with the RBR850 Router?
    "Works with" is ambiguous.
    • The RBS50Y will connect to ANY WiFi router (from any manufacturer) as a WiFi "extender".
      This will be like connecting any random WiFi extender.  i.e. a separate WiFi network, even if it has the identical SSID/password.
    • The RBS50Y will connect to the original residential Orbi routers as an Orbi satellite.
    The bottom line is that it can be done, but will have some "disappointments".  Putting a real AX satellite in a weatherproof enclosure is probably a more satisfying solution.
