Agra
Aug 16, 2018Aspirant
Outdoor smart plug that works with 5Ghz Orbi?
Hi,  I'm trying to hook up my patio lights through an outdoor smart plug. I can't get the plug to connect to the wifi because they all say they're 2.4Ghz only. I know that or I assigns 2.4 and 5 autom...
randomousity
Dec 09, 2018Luminary
You can try following the instructions here to temporarily disable 5GHz wifi while you add your 2.4GHz devices, then re-enable 5G once it's done. https://community.netgear.com/t5/Orbi/HOW-TO-DISABLE-5G-TEMPORARILY-ON-ORBI-ROUTER/m-p/1469365
