masteroftheflam's avatar
Jan 10, 2019
outside of network access
have had my orbi for 3+ years, always worked perfect. have been able to access my WD mycloud NAS from with smart phone, pc etc., from outside the network with no issues. all of a sudden I no longer have access except from within network.I believe I inadvertantly changed a setting but can't figure out where. HELP
  • FURRYe38's avatar
    Do you remember what area you were working in on the Orbi router that you might have made changes?
    Port Forwarding or Access Controls?
    I would check the following areas:
    - UPnP & Port forwarding
    - DDNS setting if you'r using one for remote access.
