Adrian97c
Oct 01, 2018Apprentice
Outside WiFi cams ignoring sats & going to router?
I just got a rbk23 kit (1 rb20 router & 2 sats), my house is 2000sqft single family, my outdoor wifi cams(1 on each corner -4total) are 2.4/5ghz WiFi... They keep connecting to the router in middle of...
Oct 01, 2018Guru - Experienced User
Alot of signal handling is done at the camera as well. It all depend on what they are set up and configured for in handling wifi signals.
What you might try is to reduce the power levels on the router from 100% to say 75 or 50% and see if the cameras connect differently. This may impact signals between the router and satellites as well.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Adrian97cOct 01, 2018ApprenticeI will disable what you suggested, but some questions:
Where do I go to “lower the strength”?
What the best way to determine which 5ghz isn’t being used? It’s set to a number like 48, there was like 4 choices to pick from.- FURRYe38Oct 01, 2018Guru - Experienced User
Adanced Tab/Advanced Settings/Wireless Settings
Try them all. However use a wifi scanner to see other neighbors near by to see what there using. Should matter for cameras. I presume they are only using 2.4Ghz?
- Adrian97cOct 01, 2018ApprenticeIs there an iOS scanner you recommend?
My cameras support both 2.4/5ghz, which prob makes it even more confusing for them with Orbi. I wish I could force connect them to 2.4ghz only & specific sat per camera.
