Dustrod
Sep 12, 2019Aspirant
p2p camera can’t login remotely using WiFi or cell iPhone
Having trouble access or login to remote P2P camera. It just not working a few weeks ago. If tried different app same issue. It seems the router is blocking access. When on home network no problem ...
Sep 12, 2019Guru - Experienced User
Please contact the Mfr for help and information regarding this camera.
Good Luck.
Dustrod
They said
Currently, there is a server issue affecting WiFi hidden cameras from all companies and manufacturers, including ours. The issue is causing intermittent connectivity issues which has resulted in some customers unable to remotely access their WiFi hidden camera w hen they are not at home.
How is this possible?
- FURRYe38Sep 12, 2019Guru - Experienced User
They will have this information. There are many factors that can contribute to internet services and servers.
Good Luck.
- Tjharris6Sep 12, 2019Guide
Check the orbi armor!! It tried the same to a lorex camera saying it was not secure enough.
- DustrodSep 20, 2019AspirantDid not work
