SeniorLouie
Sep 03, 2020Aspirant
Painted in a corner with RBR40
So I started a discussion a couple of days ago on my Orbi RBR40 and adding another sattelite to the three I have. In looking for suitable options for the satelites I am finding any ones recommended t...
- Sep 03, 2020
SeniorLouie wrote:Not to question you - will it work with the RBR40? Sounds like it will and that would be fantastic news - I like my RBR40 and really do not want to get rid of it if I don't have to. Please let me know and thanks for your reply.
Yes it will work perfectly with the RBR40 and have the same power as the RBS40.
Here are the specs:
It's AC2200 Tri Band
2.4GHz (400Mbps†) + 5GHz (867Mbps†) for WiFi devices to connect to the Internet5GHz (867Mbps†) dedicated WiFi link for faster data connections between Orbi router and Orbi Voice
3.5” front-facing woofer & 1” tweeter
35 watts with Four (4) mics with far-field voice recognition support
Two (2) 10/100/1000Mbps ports
Four (4) high-performance antennas with high-powered amplifiers
Implicit & explicit Beamforming for 2.4 and 5 GHz bands
Mu-MIMO Simultaneous data streaming to multiple devices
SeniorLouie
Mstrbig
Sep 03, 2020Master
Here are the specs:
- SeniorLouieSep 03, 2020Aspirant
Perfect thank you so much - just order it - on back order but what a steal - thank you so much for the help.
- MstrbigSep 03, 2020Master
SeniorLouie wrote:Perfect thank you so much - just order it - on back order but what a steal - thank you so much for the help.
It looks like it is available at this link if you don't want to wait:
