NL93's avatar
NL93
Follower
Jul 30, 2017
Panasonic IP Cam Bl-VT164 unstable connection with Orbi solution sharing
I encounter connection failure with my Panasonic BL-VT164 after using ORBI on almost every 2 days. The short term solution did is simply reconnect the cable but its so annoying. After many trial and error (which I found the service supporting team in Hong Kong is not knowledge enough in my case) , I found the final solution is simply forward the internal port in the advance setting and that is it. now connection is fast and stable. wish everyone enjoy ORBI.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello NL93
    Thanks for sharing that port forwarding fixed the issue.
    DarrenM
