Rlmadia65
Aug 03, 2019Follower
Pandora from iPhone won’t play just buffers , just switched to Orbi rbk50 system
Hello, I previously used my FIOS gateway to connect all my devices. I had a Yamaha receiver with MusicCast installed last year. WIFI signal strength terrible so I purchased the recommended Netgear Orbi tri-mesh system which is compatible with FIOS. It’s connected, great range and speed, but many of my apps and simple updates of iPhone apps no longer work unless I disconnect WIFI, which defeats the purpose of why I bought it. Pandora is the biggest pain. Won’t play either buffers or I get an error telling me pick anther station. Can someone help me?
1 Reply
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 or #3...
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
