tripleg
May 31, 2019Aspirant
Pandora won't stream
I just installed an Orbi system with 2 satellites yesterday. Now when I try to play Pandora via WiFi, it queues up a song, never plays and instead cycles to the next. ad infinitum. I've already re...
tripleg
I'm not able to use IP passthru as I have that already dedicated to another system that requires a WAN IP. Therefore if this is the only way it will work then I will need to return this product as it won't work
May 31, 2019Guru - Experienced User
Try option 3 then.
tripleg wrote:I'm not able to use IP passthru as I have that already dedicated to another system that requires a WAN IP. Therefore if this is the only way it will work then I will need to return this product as it won't work
- triplegMay 31, 2019Aspirant
thankyou after changing to AP mode it's working
- FURRYe38May 31, 2019Guru - Experienced User
Your ISP modem is the issue with already having a router online so two routers causes problems. DMZ or IP Passthrough fixes this however since you have that for something else, AP mode is the fix for your configuration..
Enjoy.
