djc6
Jan 01, 2018Luminary
Parent control performing minimal filtering while set to high
In "Live Parental Controls" I logged in with my pre-existing OpenDNS account, and I set filtering level to High as a test and set it for 'all times' (the default). However, only minimal filtering is occuring - not high.
I confirmed I see OpenDNS DNS servers in the router config page. Additionally, I confirmed my devices are set to use 192.168.1.1 as DNS server. I followed these steps to confirm OpenDNS resolvers are being used by my devices:
If I go to https://welcome.opendns.com/ it says I am using OpenDNS. Additionally, if I go to http://www.internetbadguys.com/ (their phish filtering test site) I see it blocked. However, if I go to http://www.exampleadultsite.com/ - OpenDNS test adult website, it is NOT filtered. Why is this? It seems I have OpenDNS configured properly, but I am only getting "Minimal" filtering (phish only) instead of "High" filtering.
My Orbi router + 2 satellites are running V2.0.0.74 - I already tried power cycling router, twice.
Whats weird is, the adult site IS blocked for a couple seconds after router is restarted, but then it only performs minimal filtering (despite config still showing 'high'). I tried switching to moderate and back to high, didn't change anything.
1 Reply
- djc6Luminary
Curiously, if I force a client to perform a DHCP release/renewal, THEN the moderate filtering takes place only on that device. However, the DNS server is 192.168.1.1 (the router) prior to DHCP release/renewal, and it remains 192.168.1.1 - so I don't know how this helps. Many of my devices are still only doing minimal filtering.. hoping as they do a DHCP lease renewal on their own the parent filtering will start to work!
