Crg1
Sep 03, 2017Star
parental control Schedule device connection
I am looking for scheduling control over specific connected devices to allow or disallow internet connection. I don't see that with Orbie or with the Genie or with the parental control page. I previo...
JGold
Oct 01, 2017Tutor
This feature would be incredibly helpful, and is very common on routers.
Specially, the ability to turn on/off access by device (not IP) based on a schedule. For example, I would like to automatically turn off access to the gaming console between 10 PM and 9 AM every day, turn off smartphone between 4 PM and 7 PM on weekdays, etc, etc.
Please advise.
RUDY06
Nov 03, 2017Aspirant
Agreed!
Scheduling is a very big missing component.
Netgear...please advise if this option will be added.
- chrisyngNov 07, 2017Initiate
You can always utilize the "Block Services" and "schedule" functions under the security tab of your router..
Create a rule to filter out all TCP service for specific IPs under the Block Services section and set it to "Per Schedule" , then go into the "Schedule" tab and set up the time frame you want things to be blocked..
Not quite as simple as some other router's parental controls, however provides the same results
