ah1
Jun 12, 2017Follower
Parental controls and website monitoring / filtering
Hi,
I've installed Orbi RBK50 with two satellites - works great!
Now, I want to get detailed reports and the ability to monitor and filter websites that my kids access. The included parental controls are pretty basic - allowing high level filtering across all devices. But I want to block specific devices from specific sites for example, and based on time of day restrictions.
Is there an easy add-on that I can use w/o too much hassle? I know there are things like wallwatcher but I've had limited success with being able to view logs in a coherent manner.
Thanks!
1 Reply
sure , under the advanced tab there are all the usual methods of blocking sites or services and schedule to set them to
monitoring however isnt available
if you have a need for this sort of capability its prob far better to have a router that can do it in front of the orbi and have the orbi itsself in AP mode
