Gilesmanners
Mar 01, 2018Aspirant
Parental controls not effective
Hi - I have enabled Parental Controls at a Low level, and yet I find that a search on free porn is able to connect and load to any of the sites that appear. So, clearly not at all effective. I have checked on several devices, rebooted the router, and I am pretty sure that I am not logged into the bypass account. So - anything else I can do?
Many thanks
1 Reply
- DarrenMSr. NETGEAR Moderator
Have you tried to set it to moderate and see a different result? You can also try to use Disney circle parental controls if you have firmware 2.1 or higher on your system.
DarrenM
