Retired_Member
Jun 30, 2017Parental Controls not working
With all of the other Orbi issues I've been experiencing this has been a low prioritiy. For months I've not been able to get the Parental Controls working on my Orbi on various firmware versions. Wh...
DarrenM
Sep 19, 2017Sr. NETGEAR Moderator
Hello Rajis and adrewery
I sent you Pms
Retired_Member
Sep 25, 2017I installed v2.0.0.74 this weekend and did a factory reset. I've setup Parental Controls and so far, so good. The problem did usually take a few days to appear so I'm keeping my fingers crossed.
- psimondoNov 13, 2017StarExactly the same issue. OpenDNS credentials simply cannot be entered in the genie app on any Apple platform. It just spins forever on iOS or kicks an error on Mac.
I’ll try a complete factory reset and see what happens.- psimondoNov 14, 2017Star
Ok. I did a factory reset and could then login with my NetGear OpenDNS login.
However, it doesn't work at all anyway.
* I set the default filtering to low.
* I then went to a device in the network map and set that device to Moderate. It saved.
* Go back an hour later and look at that device and it's back to default filter settings.
I tried many devices in my house. Same issue. It doesn't stick at all.
I then tried making the default Moderate and then going to devices to make them lower. It then suddenly says my own device is using a ByPass account and I need to log out of that. Well I NEVER set up a bypass account at all, so WTF? (I then tried setting up a bypass account so I could log out of the thing I never created and never logged in as... didnt work)
Then I went to bed. Woke up and opened up Genie and it asked me to log in with my Netgear OpenDNS login again because it seems to have forgotten I did anything. Oh but now I can't log in at all! I'm back to the same 'cant log in at all' stuff that I had to do a factory reset to fix.
TOTALLY AND ABSOLUTELY BROKEN. Truly false advertising. What a waste of money and time so far.
- Retired_MemberNov 16, 2017
My parental controls worked fine for a few weeks and now I'm getting the same problem again. Only a complete reset and manually setting up the Orbi again will fix it. So frustrating. @DarrenM
