atlpaul
Oct 24, 2020Aspirant
Parental controls revert to not enabled
I have an RBR20 with two satellites and have had constant issues with the parental controls, which was the primary reason I chose Orbi over other mesh offerings. The parental controls will go to a no...
atlpaul
Oct 26, 2020Aspirant
My firmware is V2.5.1.16 and I have AT&T fiber. The modem is an Arris BGW-210-700 setup in passthrough (bridge) mode. I'm using the built-in Circle parental controls and have a paid subscription. From a wifi and internet standpoint, everything is fine, but the parental controls won't stay working. They may work fine for a week or two and then I go in to the Circle app to make a change and I get a message that it can't detect a circle device. I then log onto the router and see that parental controls show as not enabled. If I set it all up again, I have to start from scratch with the Circle settings which is rather painful to do because it's so hard to idenfity the various devices inside Circle. Even though you can backup your Circle settings, they never restore after this happens. Parental controls aren't much good if they constantly get turned off.
I'm pretty annoyed with Netgear since I opened a ticket while under warranty, but now my warranty has expired and they won't continue to address the issue. This wasn't a cheap router and Circle was the entire reason I chose the Orbi. I will definitely quit recommending Netgear to friends when asked.
Oct 26, 2020Guru - Experienced User
Please contact a forum moderator to help you out.
Good Luck.
- FURRYe38Oct 26, 2020Guru - Experienced User
Please post about this in the Circle app forum as well:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
