kigp
May 13, 2019Tutor
Parental Controls
I have set parental control time limits on my RBR50 but they do not work. I don't want the bullroar disney control I just want my router to shut off at a specific time on school nights. is the Orbi u...
- May 14, 2019
Re-booted my orbi and selected add in block services. Now I get a list and options for blocking. I do not know why the add did not work before. I am going to try and will get back to the forum if it still does not work.
SW_
May 13, 2019Prodigy
kigp, you can still achieve this without Mickey, but Orbi limits you to a single schedule, i.e., block internet for a particular device(s) every school night between 5:00PM-10:00PM, except weekend. If you need multiple schedules to block more than one time slots, then it's not possible with vanila Orbi.
kigp
May 14, 2019Tutor
I have a single schedule and wish to stop all router activity from 10 PM to 4 AM on school nights. I do not use genie, simply log into my orbi. I have enabled standard parental controls. I have completed the schedule for days to limit and entered the start and stop blocking time. I have also enabled services blocking and selected "as per table". However nothing happens when I click on services table. Also, if I select "edit services" it looks like I should have services to edit come up but the window says failure at the upper left where block services is normally shown. The list is empty. My firmware is up to date. Am I missing something?
- kigpMay 14, 2019Tutor
