NDH
Jun 06, 2019Aspirant
Part backhaul ethernet and part WiFi
Hey all đ i have the AC2200 kit arriving tomorrow (router plus 2 satellites), and was looking for an answer I canât find. Ill have the router set up as an AP next to the old sky router (UK)...
NDH
Jun 07, 2019Aspirant
Thanks :D
I'm all set up now, and it's working great.
I haven't actively disabled daisy chain? Do I need to do that?
I have the router plugged into my Sky Hub via ethernet (wifi off on sky hub).
1st Satellite is wireless in the lounge.
2nd Satellite is wireless upstairs, but it is connected via ethernet to the PS4 (which gives a quicker connection that when the powerline was connected to the PS4!)
What should I change?
Jun 07, 2019Guru - Experienced User
It would be recommended to disable Daisy Chain if you seem to exhibit problems.
FYI about your modem:
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- NDHJun 07, 2019Aspirant
Thank you :)
I've just configued the Orbi to AP mode - I'm with Sky (UK) and they are notroious for not letting customers use their own kit.
I think the restrictions have relaced slightly, so if anyone knows how to put the Sky Hub into transparent bridge mode, I'd love to know!
- FURRYe38Jun 07, 2019Guru - Experienced User
Enjoy. :smileywink:
- NDHJun 08, 2019AspirantHey again đ
Iâve searched for this, and your answer seems to pop up quite often.
Iâm currently using the Orbi router in AP mode (because the Sky Hub is a nightmare and doesnât support modem only mode).
But this removes some of the Orbi router functionality (like switching off devices from the Orbi app).
I see you mention adding the Orbi Router IP address into the default DMZ field on the Sky IP page (portal).
Is there anything else I need to do? I turned off DHCP on the sky page as well (as I saw I needed to do that), but not IPv6 or anything.
This basically bricked everything and made the internet unusable (couldnât log back into the Sky portal), but the Orbi was still broadcasting a signal (just couldnât actually use the internet).
So did I miss something out?
Also, is this a better way of configuring it over simply using the Orbi in AP mode?
Thanks in advance!
