stickooo
Mar 20, 2022Initiate
Partial upgrade from RBR50 to Orbi Wifi 6
Hi,
I am thinking to upgrade my RBR50 (wifi 5) partially to wifi 6. Currently my setup is, I have RBR50 and 2 satelites connected with LAN.
If I get RBR850,
1. Will my current satellites (connected with LAN) still working properly?
2. I am assuming that if the device is connected to Wifi RBR850, then it will get wifi 6 otherwise it will still connected to wifi 5. Is this correct? Or everything will be downgraded to Wifi 5 since not all mesh are in Wifi 6?
3. Is it best to get the:
(a) Router wifi 6 and Satellite wifi 5 OR
(b) Router wifi 5 and Satellite Wifi 6
What is the best combo (everything will still be Orbi)
upgrading the whole system to wifi 6 is just plain to expensive, so this is why i'm planning to partially upgrade to wifi 6 until all old Orbi need to be replaced.
regards
Mike
I've heard/read that if you connect a rbs50 to the orbi setup hardwired it'll work. but it doesn't integrate with the system. So its not really compatible.
What you could do so you'd have a little more integration?
Go RBK850--->RBR50 (in access point mode)---->RBS50
The RBK50 series was the top performing AC router. What speeds do you pay for that you think upgrading to wifi 6 will be beneficial?
And do you have any wifi 6 (AX) devices?
- stickoooInitiate
I have few apple devices that support Wifi 6
Do you think the mesh network would work between RBK 850 and RBS50 assuming it's all in the same SSID?
What I like the most about mesh is it always select the strongest satellite, and drop the weakest one without having to do it manually
I don't have an 8 series to connect and see how it functions.
I've just read a few posts on there that you can hardwire wire a satellite in and it works but doesn't integrate.
IF you connect it with the rbk850 setup and then connect the rbk50 series in access point mode, then I wouldn't use the same ssid as devices wouldn't roam properly
