Mts362
May 21, 2019Aspirant
Password continually needed
Orbi based network requires my password be entered on my phone 1-2 times each day. Pretty frustrating.
May 21, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Have never seen this my self or others haven't posted about it...
- Mts362May 21, 2019Aspirant
Firmware on main router is V2.3.1.60. Operating a single (wired) satellite with same firmware. Connected to a TP-LINK TC-7610 modem. Both router and access point show up as "green" in the Orbi app. The problem does not appear to be happening with other devices like my laptop....so I get that it is largely a device issue. But at the same time, the phone has never had this issue with any other (of probably ~50 over the last 2 years) wifi networks. So maybe there is a specific interaction issue at play. Thanks!
- FURRYe38May 21, 2019Guru - Experienced User
IF other wifi devices do not exhibit this issue and the problem is only with the phone then possbible that something on the phone and recently taken a bad turn.
Have you forgotten the current wireless profile, powered OFF the phone and back on and then re-entered the SSID and PW?
AFter updating to v60, was this updated and continued or has a factory reset and setup from scratch been performed?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
