Mts362
May 21, 2019Aspirant
Password continually needed
Orbi based network requires my password be entered on my phone 1-2 times each day. Pretty frustrating.
surgio98
May 21, 2019Initiate
On Android there is an App Cache and App Data. Cache is like the memory being used currently in the app and Data is like the long term storage the app uses. I would do the following.
Us my user name and password from another device to make sure it's correct. Then wipe App Cache and App Data. Restart Phone and then login.
surgio98
Cont'd Deleting apps do not always remove their app data (Not sure about Cache). So even if you deleted and re-installed the app I would follow the aforementioned steps.
