dannycar1
Apr 07, 2019Aspirant
Password issues
I forgot my password for my Orbi network. How can I reset it?
dannycar1
My admin password
- michaelkenwardApr 08, 2019Guru - Experienced User
If digging around in your memory fails, and you have not setup password recovery, then there may be no alternative but to factory reset the router.
You don't say what the model number is so I can't point you at the manual.
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
Look in the manual for the sections Recover the admin Password and Factory Settings for Orbi Routers.
