dannycar1
Apr 07, 2019Aspirant
Password issues
I forgot my password for my Orbi network. How can I reset it?
Afflospark
Apr 12, 2019Guide
Hello,
If you want to recover your Orbi wifi system's admin password
1. You have to open http://orbilogin.com in your brawser then a login windows opens.
2. If there your passward recovery is enabled, The put there your orbi serial number
(you can find your serial number is on the orbi router product label)
3.Then enter your serial number and press continue.
4. Then they will ask you some security questions and click the countinue button.
5. Then click to login again button.
By that way you can recover your password, log in to the router.
Hope this will help you.
Regards
Afflospark
