Gellie
Jun 20, 2018Aspirant
Password not accepted
New Orbi set up. In the house everything works fine. Problem is when I go out in my yard (approx 25-30 ft from statelite) I loose internet connection on my Iphone. I see my Orbi network(strong single...
Jun 20, 2018Guru - Experienced User
Use the forget this network on the iphone, then back out then try to rejoin again. Sometimes the prior network caches and config needs to be cleared on the iphone.
Works inside the home right?
Gellie
Thx, I have tried setting th network settings on my Iphone. No help. But i'll try forgetting network to see if that helps. Yes work inside.
