R6o6d6's avatar
R6o6d6
Follower
Jun 12, 2022
Password on orbi 17
Orbi won't connect . It says my password is incorrect
1 Reply
  • FURRYe38's avatar
    You gave us nothing to go off.
    What NG product model are you referring too?
    To get a hold of support. Click on "MyNetgear" at the top.
    Register an account (or login) and then the device.
    From there you can start the support process. Keep in mind that its only free for the first 90 days.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there
