leahkushner
Jun 04, 2020Aspirant
Password Recovery does not work Orbi RBK53
Help! I set up the RBK53. I then went on my browser to get online and my security passwords did not work. I assumed it was my fault transposing the letters. I then reinstalled everything all ove...
Jun 04, 2020Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in until the top led turns on AMBER then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
