xgriff
Jul 29, 2018Aspirant
password recovery fails
Hi,
Been very impressed by the Orbi RBK53 (Router plus 2 satellites) since my first attempt at mesh wifi failed with a BT Wholehome product.
My issue today is that the app has upgraded on my iph...
xgriff
Thanks for the reply ; I'm attempting the password recovery through a browser on my Mac, and that's where it's getting stuck. I'm going in through routerlogin.net but I've also tried orbilogin.com and orbilogin.net - and each one asks me the same 2 security questions, one of which I've definitely not set up.
Jul 29, 2018Guru - Experienced User
You'll need to factory reset the router base and then walk thru the setup wizard. This will ask you the two security questions. Write them down for safe keeping and use later on if need.
