KMWNAZ
May 01, 2019Tutor
Password Reset -
Somehow user and password are not working. any way to reset it easily? I've read that logging into Mynetgear and the registered product can elect to "reset password" but that option doesn't appear ...
- May 06, 2019
Yes, I've been using the word "bridge" apparently incorrectly for AP mode. This is how it was setup before I could not get back in. Still not sure what cause the original password that was set to not work. Nonetless I reset it, an dreconfigured it to where it was. Appreciate everyones willingness to help.
michaelkenward
May 06, 2019Guru - Experienced User
KMWNAZ wrote:
I've read that logging into Mynetgear and the registered product can elect to "reset password" ....
Where did you read that?
You don't say which Orbi device you are using, or which passwords you want to change.
There is support for the Orbi WiFi System, including a manual, somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
Search the manual for "password" and it will explain what to do with the various passwords that you can have on these devices.
- KMWNAZMay 06, 2019Tutor
Thanks for your help.
Where did you read that? I read this here https://kb.netgear.com/000059608/How-do-I-reset-the-admin-password-on-my-NETGEAR-router
Sorry it's RBR50-100NAS
>>>> Orbi RBK50 | WiFi System | NETGEAR Support<<<<
This doesn't appear to workfor me as the Orbiis set to bridge mode.
