KMWNAZ
May 01, 2019Tutor
Password Reset -
Somehow user and password are not working. any way to reset it easily? I've read that logging into Mynetgear and the registered product can elect to "reset password" but that option doesn't appear ...
- May 06, 2019
Yes, I've been using the word "bridge" apparently incorrectly for AP mode. This is how it was setup before I could not get back in. Still not sure what cause the original password that was set to not work. Nonetless I reset it, an dreconfigured it to where it was. Appreciate everyones willingness to help.
Blanca_O
May 05, 2019NETGEAR Employee Retired
Hi KMWNAZ
If you are unable to log into the router settings page then there is an option to recover the System's admin password. Here's the reference: https://kb.netgear.com/31016/
Blanca
Community Team
KMWNAZ
May 06, 2019Tutor
Blanca, thanks for the rpely. I am not able to log into orbilogin.com I believe it is becasue the router is set to bridge mode.
