KMWNAZ
May 01, 2019Tutor
Password Reset -
Somehow user and password are not working. any way to reset it easily? I've read that logging into Mynetgear and the registered product can elect to "reset password" but that option doesn't appear ...
- May 06, 2019
Yes, I've been using the word "bridge" apparently incorrectly for AP mode. This is how it was setup before I could not get back in. Still not sure what cause the original password that was set to not work. Nonetless I reset it, an dreconfigured it to where it was. Appreciate everyones willingness to help.
KMWNAZ
May 06, 2019Tutor
Blanca, thanks for the rpely. I am not able to log into orbilogin.com I believe it is becasue the router is set to bridge mode.
May 06, 2019Guru - Experienced User
You'll need to factory reset the Orbi and walk thru the setup wizard and setup the router from scratch. This time be sure to write down all important information for safe keeping and later use.
