KMWNAZ
May 01, 2019Tutor
Password Reset -
Somehow user and password are not working. any way to reset it easily? I've read that logging into Mynetgear and the registered product can elect to "reset password" but that option doesn't appear ...
- May 06, 2019
Yes, I've been using the word "bridge" apparently incorrectly for AP mode. This is how it was setup before I could not get back in. Still not sure what cause the original password that was set to not work. Nonetless I reset it, an dreconfigured it to where it was. Appreciate everyones willingness to help.
May 06, 2019Guru - Experienced User
A configuration should look like this:
ISP Modem>Apple Router in router mode>Orbi in AP mode.
KMWNAZ
May 06, 2019Tutor
