tresfenton
Apr 29, 2018Tutor
Password reset impossible
After deleting browser history, cookies, etc, still impossible to go to routerlogin.net or .com. Same with orbilogin.com. When I was able to use my iPhone connected to the Orbi network, and tried r...
markoshust
Sep 01, 2018Aspirant
This works. However, there are two important issues specifically when setting up a new Orbi from a mobile device:
- It does not prompt you for an admin password
- The password challenge questions are not asked to the user, at least the first question is not. I received the same security question and I never remember filling it out. It appeared my second security question was properly picked though.
Sep 01, 2018Guru - Experienced User
Try setting up with a PC first and walk the setup wizard.
Ya I think the app needs to be reviewed for setup and reset processes...
