jwhelan70
Jun 05, 2019Tutor
Password reset not working
The password reset just doest work. it asks me for my serial, the 2 secret question. blink a new password at mico second spend the crashes.
- Jun 29, 2019
I was able to work around this bug by recording my screen during the recovery process. From there simply pause the video at the point where it flashes the new password.
CrimpOn
Jun 05, 2019Guru - Experienced User
I have changed password a number of times. The security questions are because the box is checked "Enable Password Reset". The security questions/answers are sent to Netgear along with the serial number so that a password reset can be performed if the user has forgotten the password. (Or, sincerely meant to type it in one way and accidentally made the same typo two times.) This has "saved my bacon" at least once. The truly paranoid person who doesn't want Netgear to know anything clears the box and goes without this feature.
I guess we should confirm whether the topic is (a) From the web interface, Advanced Tab, Administration, Set Password, or (b) the Orbi is rejecting connection and the user is attempting to use the security reset mechanism. If (b) is the case and the user cannot get past it, then it is time to get out the paperclip and set it up from scratch.
- jwhelan70Jun 05, 2019Tutor
yeah, I know about the serial number and security questions. I anwer them correclty. I click ok, its looks like its going to work, flash the new password quicker than a blink, and then it crashes. I tested this on # laptop and a PC. Orbi crashes everytime. it work let me reset the password. I know my serial number and security questions very well, I enter them in correctly, Orbi says I enter them correclty. the issue Orbi crashes and does work.
- CrimpOnJun 05, 2019Guru - Experienced User
It doesn't seem like there are many options. The only thing left is a "factory reset". Pain in the rear, for sure.
- michaelkenwardJun 06, 2019Guru - Experienced User
But did you actually set them up with your answers?
There is a bug in some devices in Netgear's implementation of password recovery. You can get locked into a close loop.
If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process because you can't answer the questions.
If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.
- Lobotommy1976Jun 26, 2019Initiate
I have the same issue.
I enter the correct answers to the security questions and it will display the admin password for a split second and than it goes back to the password recovery page!
Serious bug in my opinion!
rgds,
Tommy
