LoraMae's avatar
LoraMae
Password reset
I'm terrible with message boards but hopeful that someone will help.  I have to do all this at work because we now have no wifi at home.  Something happened and Orbi50 no longer works.  I can use ethernet to connect to my modem and I know that the modem is not our problem.  Orbi worked for the last 3 months just fine and suddenly, we're having problems.  I decided to just start over with Orbi.  I used the QR scan and pretended to start from scratch.  When using my cell phone to manage this, I get to the part to enter the password and the orginal default password doesn't work.  I get an error message.  I tried the password I changed it to when I first set up Orbi.  It doesn't work.  I tried the network password I had it set to when the system went down and it doesn't work.  I'm so frustrated and have nobody to ask.  The message boards give me too much detailed info and I'm not skilled enough to interpret this info.  We paid a lot for this system with its satelites last spring and now it seems useless.
  • FURRYe38's avatar
    Please factory reset the Orbi router and use either a ethernet wired PC or a wireless PC connected to the router. Then connect to the routers log in web page at 192.168.1.1 or orbilogin.com and walk thru the set up wizard. This time filling all important information, write this information down someplace for safe keeping if needed.
    • LoraMae's avatar
      LoraMae
      I've tried to establish a new account. Even when using a new email and starting over, I get the same password error message that states password unchanged.
      • FURRYe38's avatar
        Are you resetting the router and walking thru the setup wizard on the router?
