dchbbc
Oct 27, 2018Apprentice
Password Reset
Hi
I am trying to reset my password on my Orbi Router. I tried the PW that I thought I used and it said no. I tried the PW on the router and it said no. I tried to answer the questions to reset it ...
- Oct 28, 2018
Hi dchbbc
Welcome to NETGEAR Community!
You may have to factory reset the router for you to access the settings page.
It appears that the latest firmware defaulted the Guest network to turn on. This was also observed by other users. To resolve this, we would have to access the Orbi settings page and disable Guest network.
Blanca
Community Team
michaelkenward
Nov 17, 2018Guru - Experienced User
BabyButts3 wrote:
I don’t know how to manually reset my password
What's the device you need to reset?
Look on the back.
Is there a little hole labelled Reset? If so, insert the end of a paperclip and press for about 10 seconds.
That puts the device back to its "out of the box" state. Then you can set it up from scratch.
DSweatyB
Dec 11, 2018Initiate
On Firmware V2.2.1.210
Product RBR50
Why is it asking me for my sister (which I don't have one) and first netgear product (who remembers that)?
I have over 20 devices connected. I really have to reset my router to gain access to orbilogin.com?
Please tell me the smart people at Netgear came up with a solution by now.
- michaelkenwardDec 12, 2018Guru - Experienced User
There is a bug in some devices in Netgear's implementation of password recovery. You can get locked into a close loop.
If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process because you can't answer the questions.
If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.
They may have, but without knowing what you are doing and what happens it is anyone's guess as to which answer applies to you.
By the way, you have joined in on an older discussion so there's a chance that the official support team will be too busy following new stuff to find your message. It is usually better to start your own fresh discussion if you want their attention.
