chetwynd's avatar
chetwynd
Follower
Oct 23, 2021
Pausing devices on Orbi RBK753S AX4200
Hi, I see there are connected devices in my Orbi app as well as the Pause button which logically suggests that by pausing, it will block that device from the internet. That doesn't seem to work. I pause my smart TV which is connected to wifi, and it still streams TV perfectly fine. What in the world am I missing?
The internet is Comcast and goes Comcast -> Motorola model (owned) -> Orbi -> Orbi satellites.
Bottom line is that I need to be able to pause devices on the fly. How do I do this?
Thank you.
1 Reply
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
    Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Good Luck.
