drdentz
Sep 13, 2019Follower
pc not connecting to orbi satellite
My pc is not connecting to the satellite. It is instead connecting to the router downstairs, while the satellite is in the same room as my pc. Orbi Satellite-1 V2.3.5.26 Any suggetions on ...
CrimpOn
Sep 13, 2019Guru - Experienced User
This is one of the most common questions people ask about Orbi. The device picks which WiFi access point it will connect to. One suggestion is to tell the PC to "forget" the Orbi WiFi. Restart the PC. Then, search for and join the Orbi network again by selecting it from the list of WiFi networks and entering the password.
An idle question: do you have "Fast Roaming" set to "on" or "off"? (On the Advanced Tab, Advanced Settings, Wireless Settings (at the very bottom)
