drdentz
Sep 13, 2019Follower
pc not connecting to orbi satellite
My pc is not connecting to the satellite. It is instead connecting to the router downstairs, while the satellite is in the same room as my pc. Orbi Satellite-1 V2.3.5.26 Any suggetions on ...
Sep 14, 2019Guru - Experienced User
Can also try turning down the power output of the wifi radio on the RBR as well. Under Advanced Tab/Advanced Settings/Wireless Settings
CrimpOn
Turning down the radio power might help, the PC will probably still have to at least disconnect from Orbi and reconnect. Reducing radio power using the Advanced tab appears to cut radio power on both the router and all of the satellites. (Which means that the total area covered may be reduced. Not a concern if it still covers everywhere it needs to.) There may be a telnet hack that can manage individual radios.
