PhantomMarth
Aug 28, 2020Aspirant
PC Satellites Ethernet Speed is same as Iphone Wifi Speed
This has really been bothering me for months now. Ever since I've move to this house I purchase the RBR40 with the router and 2 satellites. I needed this because my modem is in the basement and I do ...
Mstrbig
Aug 28, 2020Master
Go to orbilogin.com and check your settings
Make sure you are on a WIFI channel with less traffic on it. You can check this with a program like NetSpot.
Under Advance > Advanced Settings > Wireless Settings Uncheck "Enable 20/40 MHz Coexistence" and "Enable Daisy-Chain Topology", Check "Enable WMM (Wi-Fi multimedia) settings", "Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices" and "Enable MU-MIMO"
- PhantomMarthAug 28, 2020Aspirant
I just did that. After I restarted router, I still get the same speeds. My Iphone get 380 and so does my pc.
- MstrbigAug 28, 2020Master
Is the network cable connected to your PC cat5 cat5e cat6? If cat5, try at least cat5e.
I purchased a cat6 from micro center not too long ago already.
