Fryy
Mar 03, 2021Aspirant
PC's not seeing wifi on satellite after power outage
Everything was setup and working fine. Had a power outage and now the 2 PC's that did connect to the satellite are not seeing the wifi network and can't connect. The satellite is connected, working...
vajim
Mar 03, 2021Master
Have you tried rebooting the pc's?
Fryy
Yes, im not that clueless :)
Pretty good with pc's, can normally fix most issues but this one has me stumped.
- plemansMar 03, 2021Guru - Experienced User
Can the pc's see any wifi networks?
What wifi adapter is in the pc's?
Did you try uninstalling/reinstalling the wireless card?
- FryyMar 03, 2021Aspirant
Yes they can see other wifi networks in the area.
One has a TP Link WN822N and the other a TP Link WN821N.
Yep uninstalled, reinstalled. Updated drivers from generic windows one to the manufactures latest.
- FryyMar 04, 2021Aspirant
Well fixed it, sort of.
Changed the SSID name and the network appeared again.
Now I just have to go around and update the wifi settings on EVERYTHING :(
