Zeke73
Apr 16, 2019Aspirant
Pentair Protocol Adaptor
I'm having trouble updating the firmware of a network attached device (Pentair Protocol Adaptor) with my new mesh network.
The firmware updating program states that the device needs to be on th...
- Apr 17, 2019
I figured out how to get a temporary static IP address for my PC and was then able to communicate with the device on the same subnet.
Firmware updated successfully. Now I can reconfigure the device to DHCP assigned addresses.
Back in business.
Thanks so much for your assistance.
Zeke73
Apr 17, 2019Aspirant
Sorry for being such a newbie, but how do I assign my PC a static IP address (temporary or otherwise).
I tried changing the address assignment on my router but that just made the internet inacessible.
CrimpOn
Apr 17, 2019Guru - Experienced User
I'm sorry. I have taken the discussion in the wrong direction. The correct "first step" is to determine how this device communicates. Does it have an ethernet port, or does it have only WiFi? My method for firmware update works ONLY if the PC and device can be connected over ethernet. The trick is to remove both devices from the network (i.e. they can't talk to anything but themselves), do the firmware update, and then put the devices back on the regular network. Without an ethernet port, that trick is impossible. Hence the question about model number. I was lookiing for the hardware specs and User Manual for the device.
Probably a more productive effort is to figure out how the device is getting an IP address of 10.0.1.72 If the Orbi DHCP is assigning IP's in the typical range of 192.168.1.x, the that IP address is not comiing from the Orbi. Is there another WiFi system active in the house?
- Zeke73Apr 17, 2019Aspirant
Back in business.
