QL
Mar 28, 2017Tutor
Performance of Orbi in AP mode with Actiontec MI424WR on FIOS
hi, My FIOS router is Actiontec MI424WR with coax connection. If I plan to use Orbi, it has to be in AP mode. If so, will the performance suffer? wired or wireless. My FIOS router is in my b...
QL
Mar 28, 2017Tutor
very helpful info!
thanks a lot.
whsbuss-1
Mar 29, 2017Apprentice
Even with FiOS TV service and the ActionTec you can run Orbi in AP mode. When I had mine setup performance was outstanding. I let the ActionTec do the routing & DHCP but did use a static IP (outside the DHCP range of the ActionTec) for the Orbi connection.
If you have FiOS, Orbi is an excellent choice.
