cwkal
Aug 13, 2020Aspirant
Performance spikes
Hi. Just set up my orbi mesh network. I am not getting great performance across the satellites-- performance drops off quickly with even a short distance. I am in a city with a lot of interference. O...
cwkal
| V2.5.1.16 |
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? I have a Nighthawk 32 cable motem attached.
What is the size of your home? Sq Ft? About 1500 sq ft and less than 30 ft between devices. Through some walls though.
What channels are you using?
| channel 48, but it looks like I only have choices of a few. My performance scan suggests others. |
Any Wifi Neighbors near by? If so, how many? Yes, lots
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced. Thanks I'll try this. Seems paradoxical to turn the power down, but let's see what happens..
Aug 13, 2020Guru - Experienced User
Is there a different model # for the modem? Like C#### or CM#### or D#### or DM####?
Having lots of nieghbors near by can cause problems. This is call wifi congestion. So in some cases reducing the power output of your system to reduce the wifi foot print and help reduce external wifi interferences helps in some cases. You don't always have to broadcast full power.
cwkal wrote:What Firmware version is currently loaded?
V2.5.1.16
