MarcoBru
Mar 01, 2020Tutor
performances RBK53 - pretty poor
In this we I installed my brand new RBK53, as substitusion of my previous network based on apple airport. I've different floor to cover with my network. I placed 1 satellite on the mezzanine, route...
Mar 01, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Is the Orbi system a new or refurbished unit from Amazon?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
MarcoBru
Mar 01, 2020Tutor
thank you for your thorough support!!!
Answers:
What Firmware is currently loaded? last one, I did the update after installation
ISP modem I don't know these data, but my connection is 30MBs. My claim is however for the internal network speed, and mostly lack of network coverage
Orbi system operating in Router and NEW
Any Wifi Neighbors near by? Yes One + guest
thanx for the hints, I'm going to test this evening!
In the meanwhite, that's the status
As I wrote, distance between router and satellite 2 is 1 floor, 3 meters in vertical.
- FURRYe38Mar 01, 2020Guru - Experienced User
MarcoBru wrote:thank you for your thorough support!!!
Answers:
What Firmware is currently loaded? last one, I did the update after installation. To confirm, v2.5.1.8?
ISP modem I don't know these data, but my connection is 30MBs. My claim is however for the internal network speed, and mostly lack of network coverage. Test both wired and wireless speeds?
As I wrote, distance between router and satellite 2 is 1 floor, 3 meters in vertical. 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
- MarcoBruMar 01, 2020Tutor
Answers:
What Firmware is currently loaded? last one, I did the update after installation. To confirm, v2.5.1.8? Just cheched now, Router Firmware Version V2.3.5.30 :-( Where can I find 2.5?? this one is recognized as the latest one
I have a NAS connected in satellite1, and a smart tv on satellite 2, now I can't stream HD video that with airport connections used to run fine
30 feets should be fine, in my case we are talking of less that 10 feets (with flooring in between). as sq feet, we are talking about 1600 each floor
