ssandheinrich
Feb 24, 2020Aspirant
Phantom VLAN
I was messing around with the VLANs on my Orbi RBR50 and it looks like I have hosed one of my ports on my satellite. It still shows as me having a VLAN set up as per the table below but when I go into the configuration to enable it, it is unchecked. I’m thinking that I need to enable SSH on my router and disable the land there. Can someone tell me the instructions on how to do both?
1 Reply
There may be some confusion. The attached screen shot shows the Connection Status which shows that one of the LAN ports has a computer attached and the other two do not. Nothing about VLAN.
Stock Orbi does not support SSH. You can activate telnet by going to the Orbi debug page: http://orbilogin.net/debug.htm
