Iketurner10
Jan 22, 2019Tutor
Philips Hue issue
Hi All,
Can somebody shed some light on why I can’t get Philips Hue to find a new device (light) please.
My setup is as follows:
1 x TalkTalk router
1 x RBR50 router and satellit...
- Jan 22, 2019Zigbee runs over 2.4Ghz. Zigbee and Wi-Fi are not supposed to interfere with each other but in my experience I have seen it happen. Move your bridge away from your router and make sure your lights aren’t near any other wifi or Bluetooth devices.
ekhalil
Jan 22, 2019Master
The communication between the Philips Hue and the light does not go through wifi or via Orbi.
I think that your question should be in another forum.
- Iketurner10Jan 22, 2019Tutor
Thanks for your reply. Which forum do you suggest?
- ekhalilJan 22, 2019Master
I suggest Philips Hue community like this one: https://philipshue.com/thread/philips-hue-bridge-cant-find-philips-hue-bulbs/
Good luck.
